Where to get the rubber inner fender well liners?
Discussion in '2nd Gen Tundras (2007-2013)' started by kenomouth64, Apr 26, 2017.
  1. Mar 27, 2019 at 3:56 PM
    NickOfTiming
    NickOfTiming New Member
    Arizona
    2010 BLACK DC 5.7 4X4
    I would keep in mind though, the clips will not allow the material to be too thick. The notch that snaps in is not far down the post. If you maybe hammer a grommet etc., might make it work.
    Rica25 likes this.
  2. Mar 27, 2019 at 4:04 PM
    Keep in mind I thought this out first. I'm quite good at this sort of thing. Check out my build thread for latest install info.The anti static rubber bench matting that I used is not only nearly indestructible but the same thickness as the OEM aprons. Came out better than new. :thumbsup:
  3. Mar 27, 2019 at 4:21 PM
    FXFormat
    FXFormat New Member
    Heh this will hinder itself useless when i'm balls deep in a mud pit
    Rica25, AnonVet and Black Wolf like this.
  4. Mar 27, 2019 at 4:25 PM
    Just make sure you power wash it off each time after mudding if you don't already..:thumbsup:
    Rica25 likes this.
  5. Apr 13, 2019 at 2:30 PM
    buffaluphagus
    buffaluphagus —————————————
    Wtf no way they are that expensive. My driver’s side starting to rip. I was thinking $5-$10 max
    Rica25 likes this.
  6. Apr 13, 2019 at 2:46 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    There are generic after market clips many hardware and auto parts stores sell that work as good or better for le$$ and you can get longer ones if using thicker material.
    If I were replacing them, i’d Consider making the rear one longer and go to behind the mud flap and add a couple more clips. That gap behind the tire would let a lot of debris through.
  7. Apr 13, 2019 at 4:11 PM
    NickOfTiming
    Arizona
  8. Apr 13, 2019 at 4:18 PM
    You painted SPC UCA's?
    Rica25 likes this.
  9. Apr 13, 2019 at 4:23 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Subbed.
  10. Apr 13, 2019 at 4:53 PM
    NickOfTiming
    Arizona
    I didn't, but they would look nice if I did.
  11. Apr 15, 2019 at 10:27 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Yep, they're crazy from Toyota. If you do search for them, there are aftermarket alternatives that are cheaper/better than the OEM stuff.
  12. Nov 28, 2019 at 3:12 PM
    Satimc
    Satimc New Member
    2010 4wd tundra trd
    Ome 612 20" wheels 33" toyo
  13. Jan 2, 2020 at 3:39 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    picked up one of theirs to replace one that tore out in the wyoming winds over christmas. haven't gotten it in, but so far i'm impressed. matches cut of the oem, much thicker and, not only do they include clips, but they put more than you need in case you break any in the future
  14. Jan 3, 2020 at 10:07 PM
    Rica25
    Ricardo
    Tulare
    How do we know what size this are......mine have been missing on both sides for over 2 yrs so I dont know how big they should be
    georgiey22 likes this.
  15. Jan 4, 2020 at 12:34 PM
    nuclearlemon
    wyoming
    2012 dc
    i can send you my old torn one. i've only got the one steer axle rearward right hand flap, but it's yours if you want.
    i got my customlinerz one installed and am very pleased with fit and function. pricey, but better than oem
    Rica25[QUOTED] likes this.
  16. Aug 15, 2020 at 8:27 AM
    Megawells
    Megawells New Member
    2008 White Tundra
    Suspension lift Diamond Back bed cover Interior LED’s Airchime K3La train horns Viair compressors 8 gallon tank
    Good thread. A lot of good ideas. Appreciate the referral to Southernstylesoffroad.com.
    Just ordered a set for my Tundra from southernstyles.
    I’ll let y’all know how they fit and attempt to post pictures.
  17. Aug 15, 2020 at 8:51 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
  18. Aug 15, 2020 at 9:03 AM
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
  19. Nov 12, 2022 at 10:08 AM
    #49
    LouieTundra
    LouieTundra New Member
    Louie
    SC
    2007 Tundra SR5 RWD
    Hewitt system air injection bypass kit. LED light upgrades interior & exterior.
    Amazon $26.50 - No arts & crafts required.
    HECASA Splash Shield Guard Flap Compatible with 2007-2020 Tundra & Sequoia Fender Liner Apron Replacement for 537360C030 537370C030
  20. Nov 12, 2022 at 3:01 PM
    #50
    Check out RAD Rubber Designs. Good stuff. Worth it.....USA made
    BlueCrushSC16 likes this.
  21. Nov 12, 2022 at 5:17 PM
    #51
    Rubberdown
  22. Nov 12, 2022 at 5:30 PM
    #52
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  23. Aug 8, 2024 at 1:45 PM
    #53
    Justin Case
    Justin Case New Member
    TX
    Just another data point. Older ebay links in thread are dead. Ordered these. About twice as thick as OEM and only $16 for all four and included connectors. They line up with old ones well. Will install next tire rotoation.
    https://www.ebay.com/itm/184713170541
    #53
  24. Sep 13, 2024 at 3:57 PM
    #54
    Fieldnstreamer
    Fieldnstreamer Cold Researcher
    Sam
    East Tn
    2006 DC Limited 4x4 Phantom Gray Pearl, 2000 AC Limited 4x4 (R.I.P.)
    Brute force bumpers/sliders, OME 3" lift, SCS ray 10 wheels, ARB onboard air compressor, GX460 big brake upgrade, JBA UCA's, siberian Bushings, RCV high clearance axles, 333 Billet steering rack clamp, TMR customs 10" front limit straps, 1" diff drop, agility customs dual battery setup/battery isolater with heavy duty wiring/ grounding cable upgrade, F-er battery tray, HFW spindle gussets, remote oil catch can,
    Do you know exactly what thickness that is? Or have a link to where I can buy the stuff?
  25. Sep 13, 2024 at 3:59 PM
    #55
    Not sure who orders our anti static rubber mats. RAD Rubber Design
  26. Sep 13, 2024 at 4:05 PM
    #56
    Fieldnstreamer
    Sam
    East Tn
    Thanks. I'll look it up. I'll measure the thickness of mine tonight. Mine are tearing and are brittle. No way I'm paying like 65$ per flap. No way I'm paying 260 for little 4 flaps. And that's before tax or shipping. I was blow away when I saw those prices. I figured 10$ each wpuld have been plenty. I'll make my own for sure.
  27. Sep 13, 2024 at 4:08 PM
    #57
    Fieldnstreamer
    Sam
    East Tn
    I just looked up rad. Unfortunately they don't offer any for first gen tundras. I guess I'll look into making my own from that antistatic mat you speak of.
  28. Sep 13, 2024 at 4:09 PM
    #58
    Google anti static rubber mats for laboratory use. Nothing tougher. I guarantee. You can trace out and cut to fit. Cut the pieces slightly oversized. Buy new fasteners from your Yota dealership
  29. Sep 13, 2024 at 4:10 PM
    #59
    Fieldnstreamer
    Sam
    East Tn
    Awesome thanks
  30. Sep 13, 2024 at 4:12 PM
    #60
    I edited my previous post^^^
