Which Bumper Shims
Discussion in 'General Tundra Discussion' started by Willskaf, Jan 15, 2020.
  1. May 19, 2022 at 9:37 AM
    2015 Inferno TRD PRO
    2015 Inferno TRD PRO New Member
    2015 Inferno Tundra TRD PRO
    Any advice on the BEST way to install the washers / nuts?
    Don't want to attempt this and break plastic.
  2. May 19, 2022 at 9:39 AM
    I suppose what I'm really asking is in yall's experience what is the easiest and most direct way to access the bumper's mounting points?
  3. May 19, 2022 at 11:32 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    From underneath the front bumper I did mine, one side at a time. Didnt have to take off the skid plate.
    Expect to muscle the bumper back onto the studs after you put your shims on.
  4. May 19, 2022 at 11:42 AM
    Many thanks!
  5. May 19, 2022 at 6:05 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Under it from the front, loosen 1 side and leave a nut at the end of one, then remove the other side 4 nuts, it's easier with a friend, have them pull straight out on the side where the nuts are removed, slide the nuts over the studs and put 1 on loosely, then do other side, I didn't have to remove anything else
  6. May 26, 2022 at 8:32 PM
    RRC
    RRC New Member
    Ronny
    21 nightshade
    How many do I need to buy to do this project? Thanks!
  7. May 27, 2022 at 2:55 AM
    Berdine
    Binghamton, NY
    8, 4 per side
  8. May 27, 2022 at 3:15 AM
    Berdine
    Binghamton, NY
    They push the bumper forward to give more clearance for larger tires, instead of cutting the bumper up.
    5N0W808[QUOTED] likes this.
  9. May 27, 2022 at 7:56 AM
    RRC
    RRC New Member
    Ronny
    21 nightshade
    Thanks!
    Berdine[QUOTED] likes this.
  10. May 27, 2022 at 9:14 AM
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    I concur with @Berdine. I went with the nuts and it worked great. Cost was maybe $5.
    Berdine likes this.
  11. Jun 8, 2022 at 11:20 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Can someone post a few pics of a 07-13 model with the 1/2” shims installed. I’m pondering 5/8-11 nuts soon for mine but hoping to see body line profile shots first.
  12. Oct 28, 2022 at 8:40 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Looking at a new bumper, may want to push it out 1/2" to clear skid plates and grille.
    Being in Canada, places like Coachbuilder and Toytec, make it hard to justify cost plus $40-$90 shipping/duty. There is a Canadian seller who makes plates for $120 shipped.
    I'd rather not stack washers or use a loose bolt to give the clearance.
    Any issues with using these? They seem like a decent alternative to the HD washers and nuts.
    Aluminum Spacer 3/4" OD x 3/8" ID x Choose Your Length, Round Spacer Unthreaded Standoff Bushing Plain Finish, Fits Screws Bolts 3/8" or M10 by Metal Spacers Online (1/2" Length, 10 Pack) https://a.co/d/3BiCZiO
    Coachbuilder1 likes this.
  13. Oct 29, 2022 at 1:12 PM
    ffdawson
    ffdawson #DBB
    NorCal
    Sandra, Sandy for short
    Rad ass parts, big tires.
    Yes the spacers you linked would certainly be sufficient. However they'll do the exact same thing the 5/8-11 nuts are doing... pushing the bumper out 1/2 inch... I could see how that aluminum bushing might be a cleaner look, but they're buried under your bumper cap so you'll never see them.
  14. Nov 2, 2022 at 1:38 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    If you need one of our front bumper shim kits let me know, we don't normally have any blemished but know we have a kit set aside.
    The round spacers or washers are tempting for allot of guys but know from testing the gap created between the frame flange and bumper won't provide the support not only in a forward or backwards load but can rack side to side. just my $0.02
  15. Apr 24, 2023 at 8:43 PM
    TeaRD
    TeaRD New Member
    2020 Crewmax Trd4x4 1794
    Ironman FCP 3/2 Lift | JBA UCAs | Spidertrax 1.25" spacers | 285/75/18 Toyo RT Trails | F/R SwayBar delete
    Thank you for this idea mate, I almost pulled the trigger on the Coachbuilder shims but this was a no brainer for about 7 bucks that I paid for the nuts at Ace Hardware. The install wasn't that bad either.
    Cheers
  16. Jun 9, 2023 at 10:26 PM
    Jemz808
    Jemz808 New Member
    Maui, Hi
    2018 SR5 Offroad
    20230507_062933.jpg Thank you for the 5/8-11 nut hack! My tires were rubbing on full turn in reverse...not anymore! Saved money by buying these nuts at the depot! Rims are 22x12 -44 offset toyo m/t 35x12.5r22. Lift is 8 inch ready lift kit. Top pic is without the 5/8 nut 20230609_191410.jpg 20230609_191428.jpg
    Shanet421 and TeaRD like this.
  17. Aug 5, 2023 at 5:05 PM
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    Can this be done without actually removing the bumper?
  18. Aug 5, 2023 at 7:45 PM
    Shanet421
    San Diego,CA
    Yes after all the bolts are loosened you can do one side then the other.
  19. Aug 5, 2023 at 7:55 PM
    #49
    BravoDeltaRomeo
    Bruce
    MB Canada
    Splurge for the bumper shim plates vs washer/nuts etc.
    It's not worth nickle and diming on a $50k or even a $10k truck. I thought about it, but after some research and insight from members, I opted for the $100 plates.
    2TunGet1[QUOTED] likes this.
  20. Aug 5, 2023 at 7:56 PM
    #50
    2TunGet1
    Thank you both, planning on 37s and I’m not sure if I want to get an aftermarket bumper yet. So….this will allow the 37s until I make up my mind.
    BravoDeltaRomeo likes this.
  21. Jun 13, 2024 at 4:51 PM
    #51
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Are there torque specs for the bumper bolts?? Thanks.
  22. Jun 13, 2024 at 5:06 PM
    #52
    Just get them good and tight....you won't have any issues.
  23. Jun 13, 2024 at 6:26 PM
    #53
    therealjonwick
    JR
    2019 OR
    Good stuff. Thanks! Putting shims in tomorrow. Getting lift and 285/70/18 put on next week. Don’t want any rubbing up front. Might not need them.
  24. Jul 20, 2024 at 4:53 PM
    #54
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    So I did the DIY shims(some nuts). Does anyone have any idea why my driver side looks pushed forward while my passenger side looks like it hasn't moved at all?
  25. Jan 23, 2025 at 7:14 PM
    #55
    phlook
    phlook New Member
    I did this today to fit
    LT285/75R18 Falken Wildpeak AT3 on my 2015. It could not have worked better. Great suggestions. I used 8 bolts from Ace and had the wife hold the end of the bumper.
    I appreciate you guys.
  26. Jan 24, 2025 at 2:00 AM
    #56
    therealjonwick
    JR
    2019 OR
    Good stuff! No rubbing on cab mount? That’s what kept me at 285/70. Was worried it would rub there.
  27. Jan 24, 2025 at 9:07 AM
    #57
    phlook
    phlook New Member
    I bought the truck used with these installed. At the time the truck had the stock wheels and had 1” spacers that prevented the rubbing.
    I recently put method 318 wheels. Because of the setback of the 318s is +18 they achieved what the spacers did on the stock wheels.
    My issue was slight rub on the front bumper inner lining.
    the last owner for sure did the mod where you cut that mould so it sits an inch or so more forward- but this bumper mod adding the bolts made it much better. So far things have been rub free.
  28. Mar 18, 2025 at 4:54 PM
    #58
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    Thanks folks, did this today with stainless 5/8 nuts. Worked great, very easy, and solved the problem.
