Wikid's Tundra
Discussion in '2.5 Gen Builds (2014-2021)' started by Wikid, Jun 9, 2015.
  1. Jul 25, 2015 at 8:26 PM
    #91
    Definitely like what you are doing. With that many lights/amps/loads etc, a good knowledge of Ohm's Law comes in handy. I want to see what you come up with the 2 battery setup. Where is the best placement for the second bat? I looked under the hood and was trying to figure out where. I'm waiting for you to figure it out. (sorry) Definitely something I want to do. I know I'm not the only one waiting in anticipation.
    TruckyTruck likes this.
  2. Jul 25, 2015 at 8:36 PM
    #92
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Man those are beautiful pictures
  3. Jul 25, 2015 at 8:42 PM
    #93
    TruckyTruck
    Gary
    Not sure if you've already been asked, but how long will the fridge run on the second battery with the truck off? Or is it meant to do that?
  4. Jul 26, 2015 at 12:09 AM
    #94
    Wikid
    Wikid [OP] New Member
    Don
    Toyota Tundra Crewmax Platinum
    On order
    With some of my other builds, I just added stuff as I went. i have learned that ends of costing more in the end, because of how many times you have to add stuff over and change your mind. That's why I like to plan it all out in advance. You still change some stuff, but it ends up being the exception.
    Definitely no room for a dual battery under the hood. I decided early on, to get a cap, so I am adding the dual to the bed, along with the controller, to keep them both charged . It will go along the fender wells and leave room for a Bedslide in the middle. My wiring runs will all come from the bed
    thank you sir !!
    Great Question
    The Engel Refrigerator draws about 2.5 amps per hour. I have a Odyssey Pc 1500 that will keep it happy for a day or so. It's all about energy management . I have a trickle charger, that will charge almost 3 amps, hard wired, to the battery . Plus the Engel will automatically switch to AC power, when it gets plugged in. I have a 3 way tap with the ac cord and the battery charger hooked up. When I get home, I just plug it in, so the battery is maintained and the frig keeps running, so I always have cold drinks. The eventual plan is to have a solar panel, to keep it charged in the field, for much longer. Remember, its summer in the Phoenix area, so the frig will work harder. In the winter, the frig will stay going good fro 2-3 days without touching it. If you were camping, just starting your truck or doing trails will recharge it too
    thanks
  5. Jul 26, 2015 at 12:18 AM
    #95
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    I'm assuming your choice on Bedslide is the 2000? This is the only one that fully extends. I had the 1500, but sent it back. It only extended 3/4, which was only 3" past tailgate. Make sure your battery and mounts have enough room. I think slider is 46" wide.
  6. Jul 26, 2015 at 8:00 AM
    #96
    Wikid
    Don
    On order
    Not sure what the Model number is, but this is what he sent me for how it will look.
    I think the measurement was 48 wide, so it will tuck pretty close to the fender well. I am basing that on how I will build the battery control center and compressor mount . I will keep it over the fender well
  7. Jul 27, 2015 at 1:54 AM
    #97
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    Better choice than I made. This is their MAX Bedslide, rated for 2000lbs. This is the only one that fully extends. Being you have a cap, should work just fine as long as you can squeeze batteries in the corners. The route I originally chose with a bed cover didn't leave me with much vertical storage left, plus the lack of extension. Hope it suits all your needs.
  8. Jul 27, 2015 at 8:47 PM
    #98
    Wikid
    Don
    On order
    Yes I could not have a Bedslide that did not open most of the way.
    I have decided to scrap the Bussman fuse.relay panel for a suggested solution . I will be installing two Switch-Pros
    http://store.switchpros.com/sp-8100-8-switch-panel-power-system/
    Posting these mods always brings out the best suggestions from friends and experts. Keep that in mind while you decide on your path :)
    tat2ude39 likes this.
  9. Jul 30, 2015 at 8:31 PM
    #99
    Wikid
    Don
    On order
    Next order of business is rack is on its way, from Equipt .
    Equipt | Roof Top Tents, Expedition Roof Racks, Dual Battery Systems, Portable Fridges
    They have a specific rack that can be mounted to the camper shell, but only be a few inches tall. Then I do all the roof rack wiring and light installation
    Next order of business is part of the on board air system http://rocksmasher.com/2wayair
    It will be a blessing to fill or deflate the tires from one spot. It really has many advantages . I will be taking a road trip to work out the details of the system and will also be an authorized dealer . This will be vehicle specific too, so there won't be any guess work and an easy installation
    Lots too do, so little time to do it :)
  10. Jul 31, 2015 at 5:45 AM
    #100
    Equipt has some pretty cool stuff. Excellent site. What do you think of trying to fit a Kinetik small form factor battery under the hood to use for lighting?
  11. Jul 31, 2015 at 6:08 AM
    #101
    Wikid
    Don
    On order
    Paul May at Equipt is a nice guy to deal with. He is knowledgeable and has lots of contacts too.
    To your question
    I just don't see enough room for it. It really needs to be a pretty substantial battery, for the lighting I have. Even though I have 2 batteries now, I almost wish one of them was a big Odyssey2150. When I ordered batteries I was thinking of all the additional weight and decided against the big one. I hope I don't have to rethink that. My truck will probably be at events and showing the systems I have, so it can sit there with a battery drain, at times
    thanks
  12. Jul 31, 2015 at 6:58 AM
    #102
    I was thinking maybe trying to fit a Kinetik in my engine compartment. They are fairly small. I'm only running a pair of 55W fogs, a pair of 100W spots, and a pair of 55W floods. I do have the 170 amp alternator. I may add a pair of cube LED's for side lighting at some point. Probably don't need the extra battery although there may be times I'll have the spots and floods on at the same time. May also add an inverter at some point too. I bookmarked Equipt. Lots of neat things there.
  13. Aug 9, 2015 at 5:51 PM
    #103
    Wikid
    Don
    On order
    The lighting begins...
    First set
    Baja Designs Squadron Pro's
    They are 42watt
    4300 lumens each
    3.6 amps each
    They are set up in the wide cornering pattern
    They look small, but pack a big punch, after the sun goes down.
    I set these up as a direct replacement to the driving lights that were already on the stock bumper. I cut off the plug and added a Delphi connector to each side . I needed to do some fancy spacers to get them to sit in the middle of the holes, but that's what makes modifying fun :)
    My first impression is, that I need to change my headlights out to match the color temp of the Squadrons, otherwise they look like candles. I will need to get 5000K .I did see a thread about LED replacement bulbs that are suppose to be 5000K replacements for headlight bulbs, but I need to investigate this further . It has to work right and cannot be cheesy.
    When I get the Switch Pro's, I may rewire this, so I can turn them on anytime, instead of only with the low beams, but we will see .
  14. Aug 10, 2015 at 9:04 PM
    #104
    Wikid
    Don
    On order
  15. Aug 11, 2015 at 5:27 AM
    #105
    This is getting real good. :popcorn:
  16. Aug 11, 2015 at 5:50 AM
    #106
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Mmmmmm goodies
  17. Aug 11, 2015 at 6:55 AM
    #107
    chphilo
    chphilo Tundra addict
    Western PA
    Beautiful things! Congrats. Looking forward to seeing them on your truck.
  18. Aug 20, 2015 at 7:59 PM
    #108
    Wikid
    Don
    On order
    Thanks much appreciated
    Made a little progress within the last few days.
    I sent out my Fender flares and door handles to be color matched Here is the result
    I had to put the chromies back on while the paint was happening
    Before
    After with one for comparison
    I always have like the clean look along the side, without color broke up
    One rub gone. Now on to the other
    This is strictly a test fit. I will put them on in the morning
    I know , I know, I need to widen the stance. I have wheel spacers on order to help with that, in hope they are in by tomorrow, since I already did the chop. I will just have to test out the clearance.. Clarence
    Fedex drop off a few boxes today
    National Luna Dual battery controller. Paul from Equipt, said it would be on it's way, day before yesterday. I guess he was right ! Along with this I order about $250 of wire products on Ebay , to do all of my wire runs. This translates into many hours in the garage, running, cutting, splicing, heat shrink, wire ties, etc .
    The other box that arrived was the Eezi Awn rack components. http://www.equipt1.com/c/roof-racks
    The rack will actually be here at the FED EX terminal tomorrow. It will be a rack that only attaches to the cap. Everything will be as far back as possible to leave the front of the Tundra roof clean. The idea is to keep it behind the sun roof. They actually have a special mounting system for the cap. Here is a link to the actual mounting system I will be using http://www.equipt1.com/item/k9-roof-rack-gutterless-rail-1600mm
    The rack is at FED EX terminal for pick up. While I am picking that up, I need to go to another truck terminal to pick up my Expedition One Rear Bumper. Lots of running around to do before the weekend :)
    Black Wolf and T-Rex266 like this.
  19. Aug 20, 2015 at 8:08 PM
    #109
    Mods upon mods upon mods!
    Wikid[OP] likes this.
  20. Aug 21, 2015 at 8:18 PM
    #110
    Wikid
    Don
    On order
    Before
  21. Aug 21, 2015 at 8:19 PM
    #111
    Wikid
    Don
    On order
    And the results..
    Black Wolf likes this.
  22. Aug 21, 2015 at 8:20 PM
    #112
    Wikid
    Don
    On order
    I will be getting busy this weekend, since I have lots of stuff to do. Now that I actually have more parts, it will come together more quickly
    Expedition One rear bumper. Tundra 2014 Bumpers | Expedition One
    I cannot say enough about how this this is packaged up. It really takes the guess work on how to install it , plus whether it would be damaged in shipping. The top of the carton was messed up, but when I opened it up, everything was foamed and plastic to protect the entire bumper
    It seems really stout too
    This also arrived today
    Superwinch Talon 12.5 Superwinch, LLC - Talon 12.5 SR – 12,500 lbs/12V
    This was also packaged well. It looks like a beast too. I am glad I got the synthetic rope. The top box is the wireless remote control
    The rest of the roof rack was in and I drove to FED EX terminal to pick it up
    I definitely have enough to do right now
    Tomorrow morning I will be heading to GMG Fabrication, to finish installing and tweaking rack/battery box/lighting control/Extremeaire mount . Its almost there, but it needs some adjustments
    I will get some pics after a few fit sessions
    Last but not least
    When I dreamed up this project, I hired Tavis Highlander Graphic Designs to create a rendering . He is amazing and put my thought to print almost exactly how I envisioned it . If you plan on building a project, that you want to set your goals for, this is the way to do it.
    I debated about posting a pic of the rendering, but since it's starting to take shape, I thought it would be fun to get impressions, of how it follows my thought . The blue highlights you see are actually the wrap I designed. It is suppose to be subtle. I want the build itself be the focus. The wrap is just suppose to be a hint of Arctic landscape
    There are some lights missing on the bumper, but I will have him add that to the rendering and get the final artwork from him when its complete
    Here is the rendering. I may or may not leave it up, but for now ...
    tat2ude39 and T-Rex266 like this.
  23. Aug 21, 2015 at 8:24 PM
    #113
    Loving it. Wikid, do you know any outfit that makes a roof rack that will fit on top of a 07 DC? For the life of me I can't find anything and I am usually pretty good about researching.
  24. Aug 21, 2015 at 8:29 PM
    #114
    Wikid
    Don
    On order
    Thank you
    Yours doesn't have gutters correct?
    You can do a rack system like I am doing Its a universal . you will have to mount the long strips through the roof and then a rack will fit on it. Means you will need to pull the headliner down, drill through silicone seal and a backing plate. it would be a tight install for sure
    Here is a link to the rails http://www.equipt1.com/i/roof-racks/custom-roof-racks/rail
  25. Aug 21, 2015 at 8:31 PM
    #115
    Joshua1271
    Joshua1271 Go Bucks
    Joshua
    The Buckeye State
    15 Tundra CM SR5 TRD
    Hope I win the lottery too... That's a sweet truck.
    650h1 likes this.
  26. Aug 21, 2015 at 8:37 PM
    #116
    Maybe it's time to switch careers for me. :help: Need to try something else. (Like working with wood). 2 more years of Metrology Engineering (37 yrs so far) and I am going to definitely make a major change. ( semi retire). I'm (all of us here) are watching this pro build that you are doing. It's greatly appreciated that you are sharing this. Going to help a lot. You are covering so many different things in one project.
  27. Aug 21, 2015 at 8:42 PM
    #117
    Yea. no gutters. Just checked the link. Certainly doable. Will take some effort. Something I really want do do. (backing plate thickness?) Maybe I should contact Equipt to get more info. Thanks.
  28. Aug 21, 2015 at 8:49 PM
    #118
    Wikid
    Don
    On order
    Talk to Paul. Tell him you talked to me about it . He is knowledgeable
  29. Aug 21, 2015 at 8:53 PM
    #119
    Will do that. Going to leave a message on Equipt now and call tomorrow too.
    Wikid[QUOTED][OP] likes this.
  30. Aug 21, 2015 at 8:56 PM
    #120
    Wikid
    Don
    On order
    Thank you. You can set goals and achieve them, if you don't mind working really hard . No lottery money for me. I am just determined to build it the way I want , then form a plan that works. We all started out hacking parts together. I prefer the research then apply method now. I want to try and spend my money once. It doesn't always work that way, but it helps to plan
    Wood working is nice, but it gets to be work too . My wrists are tired of sanding and running a sprayer. I try to let my crews do most of the work now. Hopefully they can just keep it going and I will eventually get more time to do this stuff :)
