Will 2018 Tundra Tow Travel Trailer?
Discussion in 'Towing & Hauling' started by KDA274, Jun 28, 2021.
  1. Jun 28, 2021 at 9:33 AM
    KDA274
    KDA274 [OP] New Member
    2018 Toyota Tundra Limited CrewMax 4x4
    Great information you just gave me and I appreciate it! I'm definitely looking into a weight distribution hitch. Do you think I would need anything else that would be a mandatory item to buy before purchasing the travel trailer?
  2. Jun 28, 2021 at 9:33 AM
    KDA274
    Great and thanks for the info!
  3. Jun 28, 2021 at 10:03 AM
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    Been thinking about a travel trailer recently, glad I popped on the towing page here before I did anything. Dealers seem to have no reservations with selling a 30ft travel trailer to people with 1/2 tons.
    Cpl_Punishment and Oey12 like this.
  4. Jun 28, 2021 at 10:08 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    It all depends on the trailer you get in the end. A properly setup Weight Distribution Hitch is most important and getting your truck and trailer weighed at a CAT scale (or similar) so you know what you are working with for weight. Also make sure you have good, properly rated tires for the weight.
    As you read through here you will see lots of comments about the rear suspension on the Tundra. It's soft and it squats under weight. Airbags are a fantastic way to eliminate squat when towing but they won't replace a good WDH. A longer watch, but this is a good one to understand:
    Next, not a purchase, but if you are generally new to trailer towing the mandatory next things is reading lots on how Tundras tow. Things like "reving an engine is not bad" and learning about transmission temps. In my opinion, I would just buy things to make you safe and then add on things after your first tow. Once you do your first trip you will find lots of goodies to buy :)
  5. Jun 28, 2021 at 10:15 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I’m saying to get both, tundra leaf spring are known to sag, towing almost max he need wdh for sure
  6. Jun 28, 2021 at 10:39 AM
    KDA274
    That is all fantastic information and thanks for taking the time to provide it! :)
  7. Jun 28, 2021 at 1:10 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I added the Firestone bags. Easy install and big difference when towing.:thumbsup:
    Cutting bump stops off was probably the worst part. Cut with a sawzall the smoke:eek2:
    szabo101 likes this.
  8. Jun 28, 2021 at 3:57 PM
    timsp8
    NY
    Not sure what the video above says, but sometimes airbags can be bad for towing. They put more weight on your rear axle than it might be able to handle. There was a good video about it that I can’t find now. This one explains it some.
    https://m.youtube.com/watch?v=NNIWCQlRdaw
  9. Jun 28, 2021 at 4:33 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    Has anyone towed a 6-7k travel trailer for an extended amount of time (10-15 hours a day) without any issues? I'm toying with the idea of getting another trailer but curious if anyone has pushed the Tundra that hard multiple days in a row. My F150 didn't like my old 9k trailer and my F250 didn't even bat an eye but I will not buy another diesel. That's also what I said about the trailer...
  10. Jun 28, 2021 at 5:23 PM
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    Yes and without any problems...I do it 3 or 4 times every year on the way out west, and back from GA. 650 to 1100 miles each day for 3 consecutive days on the way out, and again on the way back. 10-15 hours each time. fullsizeoutput_a7c.jpg
  11. Jun 28, 2021 at 6:05 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    Excellent to hear! When I go to Montana it's two long days like that. Thanks for the feedback
