X2 27F battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oz_zy, Jan 30, 2023.
  1. Feb 1, 2023 at 10:22 AM
    AZBoatHauler
    So.Arizona
    That’s cool - mine hovered between 13.4-13.7. Maybe 13.9 on a cold morning start. Never touched 14 without a diode. With the HKB I still only get 14.0-14.3.
  2. Feb 1, 2023 at 10:25 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Using the fuse will bump up that charging a little bit and it's better for the battery!
  3. Feb 1, 2023 at 4:23 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    When did you buy the bad one? Prior to this Tundra I had an Expedition and tons of folks had these batteries (including myself on multiple vehicles) with zero issues on the Expedition forums. Then all the sudden about 2 years ago a number of folks on the board had failures with in a year.
    All were quickly handled with a warranty replacement quickly except for 1. That seemed to be an individual Batteries+ location issue.
    After that little stint I read of no more issues. Thinking they got a bad batch of some part of the battery and had issues for a short time.
  4. Feb 1, 2023 at 5:19 PM
    AZTundra
    Paul
    Phoenix, AZ
    The original X2 was purchased and installed on 12/05/2021. That battery lasted until December 2022 (~12 months) before dying.
  5. Feb 1, 2023 at 5:22 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Diode works good for me. At least 3 years, and no issues.
    Sonicbluerider likes this.
  6. Feb 2, 2023 at 3:00 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Your can get a couple of inline fuse holders and wire the diode and a fuse in series if your concerned about protecting that circuit.
    JINKSTER17, Oz_zy[OP] and texasrho83 like this.
  7. Feb 2, 2023 at 3:54 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did this myself.
    I made the switch from the HBK to the diode and have had way better results with the diode.
    Oz_zy[OP] likes this.
  8. Feb 2, 2023 at 5:22 PM
    Wallygator
    Right at about 4 years now in two different vehicles, with a hookup to the charger once a month. No diode.
    NewImprovedRon and Sierradevil like this.
  9. Apr 22, 2023 at 7:04 AM
    JINKSTER17
    JINKSTER17 New Member
    William
    2019 Super White TRD Crewmax Limited
    I just became a member of this forum today and ironically was directed here by another member to review charging issues with the brand new X2 27F I purchased yesterday to replace the Johnson Controls OEM battery in my 2019 TRD that began leaking acid and now I’m reading that its suggested to add in a voltage boosting fuse link?
    I can’t help but wonder if the contrary results we’re seeing here is a result of the difference in charging systems between Tow Pkg equipped Tundra’s and those that are not because the tow package in my Tundra specs includes a Heavy Duty Battery and a 170amp Alternator. Now I don’t know what size alternator the non tow package equipped Tunda charging system has but can’t help but wonder if those aren’t the one’s not up to the task of keeping a 27 series AGM sufficiently charged.
    For amusement here’s some pix of my battery swap out yesterday…
  10. Apr 22, 2023 at 7:08 AM
    JINKSTER17
    William
  11. Apr 22, 2023 at 7:14 AM
    JINKSTER17
    William
    Looking in my fuse box I see a place for “BATT CHG” but its not a 2blade fuse and I think this might be the 4-/7-pin connector that’s also specified with that tow pkg 170amp alternator but I’m still not sure if I should be adding supplementary charging methods as this is my first AGM battery.3E727E01-7E96-447D-84AB-8814426D9191.jpg
  12. Apr 22, 2023 at 7:18 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    You replace the “ALT-S” 5A fuse, not the relay.
  13. Apr 22, 2023 at 7:20 AM
    coTony
    Tony
    Montrose, CO
    What app is that displaying the voltage? Looks like Fusion but I never seen just text being displayed and no gauge surrounding it
  14. Apr 22, 2023 at 10:46 AM
    JINKSTER17
    William
    Well, it’s been a very interesting 24 hour journey with my first ever AGM battery, and now a diode replacing my fuse which I got at O’Reilly’s. What was really interesting was I had the tech at O’Reilly’s test my charging system with the 5amp due in place and his meter said everything was passing but volts was down around 13.6/13.5 and when he had me turn on my lights and high beams I no sooner backed out of the cab and he said “Shut it down. Your voltage regulator just failed”.
    So I then put in the $5 GM diode and he retested and said “Well somebody on the internet knew what they were talking about” telling me that even with my high beams and A/C running he was getting 13.7/13.8 so then I went to autozone and had the system checked again but their tester only spit out a receipt saying my voltage/diodes/voltage regulator “Passed” so I went in and bought my own first ever cheaply multimeter and it says 13.81
    So now I’m thinking I want one of those fancy shmancy adjustable diode thingies so I can dial in for 14.2-3 so a shopping I will go.
    Thanks to everyone here. You’ve been very helpful.
    WVI, AZTundra and TRDFerguson like this.
  15. Apr 22, 2023 at 1:46 PM
    JINKSTER17
    William
    Update/Important: So at Oriellys we just sort of stuck the GM diode in there as best we could so my numbers above were with the diode not properly fitted/seated. (I honestly didn't think it would make a difference) but for gits a shiggles I pulled it and used a dremel to shape the sides to fit and seat properly then put my multimeter to it again where at idle I was getting 14.2-14.3 with no load but no revs either so?...close enough! :)
    WVI likes this.
  16. Apr 23, 2023 at 12:08 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Never buy anything from Batteries Plus without a coupon or discount code.
  17. Apr 23, 2023 at 12:25 PM
    Markysharky
    Markysharky New Member
    I used to work there for many years, there’s always atleast a 10% discount code or better on everything. X2 are good batteries. Made by Northstar battery.
    JINKSTER17 likes this.
  18. Apr 25, 2023 at 11:18 AM
    JINKSTER17
    William
    I asked and the young man knocked off the tax and yes, most reviews and experiences of the X2 that I’ve read are positive to glowing with but a few sour grapes experiences which at this point in my 1st AGM deep cycle learning curve I would write off to charging issues that didn’t get addressed up front.
    Edit/PS: I might add that on day 2 I clipped a smart charger on my new X2 only to discover it was only 40+% charged (my charger has 20% graduations) and it took about 4 hrs to bring it up to 100% last night.
  19. May 19, 2023 at 11:49 AM
    #49
    Wallygator
    Or just put in it on a battery charger every month like I have going on 4 years now. Battery seems very happy. I use a Ctek 7002 charger.
    Teamrivers likes this.
