Yellow Box Speedo Calibrator
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, Sep 22, 2018.
  1. Jan 10, 2024 at 3:30 PM
    #181
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Did you make this plug n play yet???
  2. Jan 10, 2024 at 4:07 PM
    #182
    If @empty_lord hasn't gotten it yet, I wonder if @daveeasa may have the apropos connectors?
    I've been thinking about YB'ing my truck as well now I've got 32.2s on it.
    CodyP[QUOTED] likes this.
  3. Jan 10, 2024 at 4:52 PM
    #183
    daveeasa
    David
    Anyone have a photo?
  4. Jan 10, 2024 at 5:07 PM
    #184
  5. Jan 10, 2024 at 5:15 PM
    #185
    daveeasa
    David
    So, we are talking about the yellr harness? The one you can buy from them? I have two of those for each of my RC’s
    I’m guessing a different connector than the one my trucks use?
  6. Jan 10, 2024 at 5:21 PM
    #186
    If I read correctly, I think the harness for the 4AT is potentially different from the 5AT connectors. But I may be misreading. 7 pages of posting. I dread going back through that.
  7. Jan 10, 2024 at 5:36 PM
    #187
    daveeasa
    David
    And Yellr does not offer the 5AT harness?
  8. Jan 10, 2024 at 5:39 PM
    #188
    I wasn't clear on that from prior pages. I'm not sure what @empty_lord was getting at. It looked - from earlier posts - like YB folks were willing to knock something out, but I didn't see where it happened.
    I'd like to YB my truck. I'd do it, if I had a weather-resilient, easy way to do it. I would probably want to bag any exposed connector I left unplugged to prevent tarnish and add easy reversibility. I like reversible mods.
  9. Jan 10, 2024 at 5:44 PM
    #189
    daveeasa
    David
    The connectors on my transmission are waterproof. So the yellr is sealed. No need to bag. I assume the same for you guys and your 5AT. Not like Toyota went backwards on that.
    I did have switch print me a box for mounting the yellr but i decided to just route it through the grommet I already trashed for my terrible tailgate lock feed.
    CodyP likes this.
  10. Jan 10, 2024 at 5:48 PM
    #190
    I mean, you'd need to bag whatever connector you're leaving open because the YB harness is replacing it? Or maybe I'm misunderstanding and the YB is intercepting vs. replacing.
  11. Jan 10, 2024 at 5:49 PM
    #191
    daveeasa
    David
    It’s a T. Both ends. It modulates the output signal off the input.
    shifty`[QUOTED] likes this.
  12. Jan 11, 2024 at 12:40 AM
    #192
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the issue is the PCB side housing doesnt seem to exist. i just forgot about this project. its honestly something someone with 3d printing skills could probably get made easily
  13. Jan 11, 2024 at 1:22 AM
    #193
    daveeasa
    David
    As in the Molex connector? And you want both sides there? What for?
    Many of these only have wire to board on the male side.
    shifty` likes this.
  14. Jan 11, 2024 at 12:45 PM
    #194
    empty_lord
    05 rollover special
    The connector on the back of the Speedo
  15. Jan 11, 2024 at 12:52 PM
    #195
    daveeasa
    David
    This is the one I could use a photo of. Given I don't own an '05 nor do I really understand what you mean about "PCB side housing".
  16. Jan 11, 2024 at 10:24 PM
    #196
    empty_lord
    05 rollover special
    id have to pop the cluster out. the 05 cluster is a PCB with the surface mount stepper motors and all that... totally different from the 04 and older trucks.
  17. Jan 12, 2024 at 5:50 AM
    #197
    Here's what the back of the '05-'06 cluster looks like, only posting for reference.
    @empty_lord are you saying there's no good way to tap/intercept the speedo signal where it comes in back here? Or are you saying someone would need to 3D print a whole new plastic backplate for some reason?
  18. Jan 12, 2024 at 4:16 PM
    #198
    empty_lord
    05 rollover special
    The connector itself IF you wanted to make a no splice t harness like I do. You can splice in with a wire tap if you wanted
  19. Jan 12, 2024 at 5:13 PM
    #199
    Why could you not just do the intercept at the other end of the run? Sorry if this is a stupid question, speed source is different on the 05-06, is there a reason you wouldn’t just use the other end of the source signal?
  20. Jan 12, 2024 at 5:53 PM
    #200
    empty_lord
    05 rollover special
    Tapping into the ABS Connector would be even more of a headache. Plus wires like this outside the car around here less to corrosion and odd wiring issues down the line
    speed signal is generated at the ABS pump with the computer.
  21. Apr 7, 2024 at 3:15 PM
    #201
    Johnw
    Johnw 2005 tundra
    Tyler
    2005 tundra dc 4.7 v8 trd
    I know I’m a couple years late so not expecting a response but what did you do with the red wire
    jerryallday likes this.
  22. Jun 19, 2024 at 7:41 PM
    #202
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    Great thread here. I assuming I need the splice harness for my 04 Sequoia. I'm assuming the wire color will be the same. Ill do more digging to find a wiring diagram for my particular year/model. I want to tap behind the gauge cluster will the length they provide be enough?
    I need to see if this will work for my 2003 GX. Its off by 5 mph at 70 mph with 32's.
  23. Jun 20, 2024 at 7:19 AM
    #203
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Jerry, the read wire is power if I remember correctly. You need to fuse it.
  24. Dec 8, 2024 at 9:25 PM
    #204
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    Think I might get one of these for my 03, because the speedo is off after going to 4.10's on stock tire size. I need to do more research first and I assume I need to figure out what percentage my speedo is off by.
    Much easier when it's because of tires size, since the tire size calculators tell you.
    I assume I can just figure out the percentage difference from 3.91 to 4.10, but I'm not certain.
  25. Dec 9, 2024 at 12:50 AM
    #205
    daveeasa
    David
    A usb gps speedometer is worthwhile. Phone app works too if you have a mount.
    455h0le_dachshund likes this.
  26. Dec 9, 2024 at 5:58 AM
    #206
    2006Tundra
    Lou
    Long Beach, CA
    Yellow Box comes with instructions/math formula on how how to accurately adjust your speedo. You don't need to know the percent difference from 3.91 to 4.10. You just need some sort of GPS speed monitor App, I used WAZE. Then you get the GPS speed and you need to write down what your physical speedometer is reading and do the math via Yellowbox.
  27. Dec 9, 2024 at 6:10 AM
    #207
    Adding onto this: If your radio has CarPlay, you can setup any route in GPS and when you go to display the map on the screen, your GPS calculated speed will show up on the screen along with the current posted speed limit.
    It's how I keep tabs on my actual speed now I'm running tires 2" over stock.
  28. Dec 9, 2024 at 8:07 AM
    #208
    daveeasa
    David
    I found my iPhone speed estimate wasn’t quite as good / responsive as the cheapo usb speedometer. Based on radar stations (we have a few near us). The phone apps I’ve used tend to lag a little bit and/or smooth the data.
    I also found the math to be less useful because of this than adjusting and road testing, then repeating. Hence a benchmark to compare to was helpful.
    And, last, from what I observed, you can match one speed pretty close but that doesn’t necessarily mean you’re quite as close higher/lower than that target speed. So you end up forced to pick the calibration sweet spot speed.
    I felt that having very accurate speed below 25 wasn’t terrible valuable, and beyond 75 it seems wasted given I don’t want to guzzle fuel or exceed the posted limit. I think I set mine up to be spot on somewhere around 50. Of course as tires wear down, or with air pressure changes or summers vs winters, you may want to re-tweak.
    Hence the value of a $30 reference device.
    455h0le_dachshund and shifty` like this.
