Yota LED Amber Grill lights ???
Discussion in 'Lighting' started by RogueAngler, Jun 2, 2021.
  1. Nov 11, 2023 at 12:50 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Change it out! Those led bulbs are sold every where. The only time mine went out was when the ground needed to be replaced
  2. Nov 14, 2023 at 2:47 PM
    Reddawg1100
    Reddawg1100 New Member
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Custom rims, front leveling spacers
    I immediately got Knight Rider vibes.. and quickly decided I need to do the same. I like the way these look!
  3. Dec 3, 2023 at 2:47 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Hi guys, I just got my '18 Tundra and am also looking at adding the amber LEDs to my truck. I love the look of both of your trucks with the LEDs being in the hood bulge. I'm debating on getting the LEDs for the hood bulge(which you both have) versus YotaLEDs grill lights that actually hook up to the grill itself.
    My concern with the hood bulge and maybe you both can provide insight is driving at highway speeds when it's raining or even just driving in general. With having removed the stock plastic insert, does water enter the hood when driving high speeds and if so, where does the water drain? My thoughts would be that the water enters and stays pooled up in there or does it escape the holes where you would have the wiring exit? That would be problematic as it would be dripping onto the electronics/battery. Am I overthinking this too much? LoL.
    I found this and really love that it replaces the plastic insert for a steel bracket plate and comes with the lights/harness and everything needed however the question about water entering comes into play...
    https://yotasupply.com/collections/...t-for-hood-scoop-bulge?variant=40173668827285
    One thing I definitly would not want to do is cut the horizontal brackets and the retaining mounts that holds the bulge piece down as I've read that at high speeds, the bulge even without modifications has history of coming loose overtime due to worn out molding clips.
    IMO I do think the best placement for the lights would be in the hood bulge only without allowing the elements to enter the hood. This is just an idea but I may consider getting YotaLEDs but remove the grill brackets and drill small enough size holes in the OEM plastic insert with rubber washers to get a good waterproof seal.
  4. Dec 3, 2023 at 3:56 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    I have the Baja Designs S8 light, it has back lighting that is amber. Living in the Phoenix area doesn't cause any concern about rain. I did remove the braces to install the light bar. The surround did come loose once due to the clips being weak, new clips solved that issue.
  5. Dec 22, 2023 at 7:41 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I also have a BD S8 in the hood bulge, using SDHQ mounts. I live in western Oregon and we have all the rain…
    For install, I cut three 3” holes with a holesaw behind the bulge for fastener access. A few splashes of water must get through because it seems like my engine cover a a fuzz dirtier than before. Otherwise, I bet the majority of any water intrusion runs out the front, under the bulge.
    Honestly, I don’t see any significant change and don’t worry about it.
  6. Dec 22, 2023 at 8:02 AM
    TacomaTRD4x402
    Southern California
    Do you have any pictures of your hood bulge light setup?
  7. Dec 22, 2023 at 2:39 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Like, how it goes in? Or just the light in the hood bulge in general?
    Not a huge photo guy and my wife just took the truck in to town with our daughter for volleyball practice. Won’t be home for a bit…
    The install is pretty well documented on SDHQ’s website.
    https://cdn.shopify.com/s/files/1/2493/2184/files/53-1203-G3_Install_Instructions.pdf?v=1625593622
    And other than the color, it looks just like this:
    https://sdhqoffroad.com/products/14-20-toyota-tundra-sdhq-built-hood-scoop-led-light-bar-mount
  8. Dec 22, 2023 at 2:55 PM
    AZ Red Nek
    Chuck
    Search for the post "hood bulge light bar" possibly have the info you're looking for.
  9. Dec 22, 2023 at 6:32 PM
    TacomaTRD4x402
    Southern California
    Ahh okay I see how you have it now. I read your post thinking that you drilled the holes in the hood bulge plastic insert for each led with a rubber washer for complete weatherproofing which is what I was considering doing at first to eliminate any possible chance of water entering the hood. After a bit of thought after my initial post I just went ahead and got the led grille lights and mounted them to the actual grille.
