Your 2nd Gen Controls And How They Work
Discussion in '2nd Gen Tundras (2007-2013)' started by TruckyTruck, Jun 30, 2014.
  1. Mar 25, 2020 at 4:49 PM
    #91
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    Yes, i believe the 4th option is being able to have only the lsd on. It should lay it out in the manual.
  2. Mar 25, 2020 at 4:50 PM
    #92
    TruckyTruck
    Gary
    Prius mode?
  3. Mar 25, 2020 at 4:51 PM
    #93
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 65mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    <Insert Mom joke here> Mode
  4. Mar 25, 2020 at 7:48 PM
    #94
    Albinator
    Albinator SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    Looks like it
  5. Mar 25, 2020 at 7:52 PM
    #95
    TruckyTruck
    Gary
    I wish it was that way with my 2013!
    2013 Tundra TRD 4X4 likes this.
  6. Mar 25, 2020 at 7:56 PM
    #96
    Albinator
    Albinator SAINTRIOT
    Utah
    Nice to have more options, but I still don’t get it well enough yet for when to use which one :facepalm:I’ll figure it out.
  7. Mar 25, 2020 at 8:07 PM
    #97
    TruckyTruck
    Gary
    I rarely take mine out of full nanny mode. But when I do, I like options!
  8. May 10, 2020 at 8:43 PM
    #98
    ANOMIC
    ANOMIC New Member
    The only downside to the VSC switch is it can’t be operated when in motion. So when you see a condition coming that you could take advantage of the different controls, you need to stop.
    They can get a mechanical system like 4WD to work on the fly but not a computer? Dumb
  9. Feb 9, 2021 at 8:38 AM
    #99
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    I'm still a little confused about the LSD. After reading through this thread, and carefully reading the manual for my 2019 4WD Limited, it looks like I need to be in 2WD in order to enable the LSD. Is that right?
    Is there no LSD in 4HI?
    I ask because I recently got stuck in heavy snow because my left rear wheel was on ice. I was in 4HI and that left rear tire would spin and the truck would not move. When I pushed the VSC button it would go to VSC off but I could not get the LSD light to come on.
    Edit: Today I pushed the VSC button in 2WD and the A LSD light came on, so that works in 2WD. I'm still confused about why it does not work in 4WD. I don't know why I would choose 2WD if I am in heavy snow. Snow is the reason I bought 4WD in the first place. Even if the LSD only affected the rear wheels it would be helpful in either 2WD or 4WD.
  10. Feb 9, 2021 at 6:35 PM
    #100
    iDon’tRead
    iDon’tRead New Member
    Does the auto lsd affect the mpg or was it just me ?
  11. Feb 9, 2021 at 6:45 PM
    #101
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It's intention is situational, not for normal motoring about. So, likely. It applies the brakes, so it will wear them too.
  12. Feb 11, 2021 at 4:30 PM
    #102
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    When going to 4hi or 4lo, the tundie switches to A-TRAC. It's the exact same as Auto-LSD but works on all 4 wheels.
    The lsd is to let the power go to one of the rear wheels that can get traction. If you're in 4wd, you have 2 extra wheels to get traction. The idea is to let the front wheels do what the rear can't or at the very least, assist the rear wheels. The a-lsd isn't needed because it has A-TRAC.
    If you're in 4hi and still stuck, go to 4lo.
    I may be wrong. Someone can correct me.
  13. Feb 14, 2021 at 12:28 PM
    #103
    Geezer
    Geezer New Member
    2019 Tundra Limited
    Thank you. I will try that. I did not try 4Lo when I was stuck in the snow. I was in 4HI and had all wheels in heavy snow. The left rear was on ice that was under the snow and it was the only tire spinning.
    This week I replaced my tires with ones that will go a lot better in the snow so I hope I am good to go.
  14. Feb 16, 2021 at 11:49 AM
    #104
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This may assist some that are newer to the Tundra with a little bit more of a visual representation of "The System".
    TruckyTruck[OP] and Ktate like this.
  15. Aug 24, 2023 at 6:25 AM
    #105
    eddly
    eddly New Member
    tundra sr5 5.7l
    Thanks!
    TruckyTruck[OP] likes this.
  16. Oct 17, 2023 at 7:58 PM
    #106
    Rathesun
    Rathesun New Member
    2013 Tundra Double-cab 5.7L engine
    Agree!
    I copied, pasted, and then printed it.
  17. May 5, 2024 at 7:01 AM
    #107
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Thanks for this thread. I have a 2wd '07 and a 4wd '10. I got the 4wd cause winter became an embarrassment.
    Whatever Toyota intended for this ALS system they failed. I've got 2 old land cruisers all mechanical. Easy.
    I will take this guide now into the bush and push and hold buttons until I figure it out. Having to come to a complete
    stop is just weird.
