Tundra throttle body coolant bypass mod
Discussion in 'Performance and Tuning' started by dirtydeeds, Jan 16, 2023.
  1. Jan 16, 2023 at 10:18 PM
    dirtydeeds
    dirtydeeds [OP] Exhaust Fabricator Vendor
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
  2. Jan 17, 2023 at 4:14 AM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    I want to do this on my 5.7 before it gets too hot
    dirtydeeds[OP] likes this.
  3. Apr 18, 2024 at 10:32 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Easy work
  4. Apr 18, 2024 at 11:04 AM
    azTony
    Tony
    Sun Lakes, AZ
    I did mine a while ago and was in Colorado for a few weeks this month and with snow and temps in the 20’s it was just fine
  5. Apr 18, 2024 at 12:59 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What size is the hose? If you used a coupler between the 2 hoses.
    azTony[QUOTED] likes this.
  6. Apr 18, 2024 at 1:22 PM
    azTony
    Tony
    Sun Lakes, AZ
    I just reused the hose I had, no need for more. I only rerouted it out of the TB
    ZPhilip[QUOTED] likes this.
  7. Apr 19, 2024 at 6:13 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Brand new cabin air filter!
    Came across this thread yesterday and got to looking into it, watched a few videos as well as Keith's up there. I never knew this was a thing. I live in Southern Cali where we never see any snow plus even on the coldest day I can't imagine my TB freezing over. Seems like people are on the fence about it providing any sort of performance or slightly improved gas mileage. :confused:
    @azTony any noticable changes after you did yours?
    Curious if anybody else has done this?
    azTony likes this.
  8. Apr 19, 2024 at 11:19 AM
    azTony
    Tony
    Sun Lakes, AZ
    I never do any of the testing before and after things just did it because of the logic behind it and never seen coolant flow through the TB on other vehicles. Sorry I cannot help
  9. Apr 19, 2024 at 11:22 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    This is one of those mods that’s probably fun to do and think about the potential benefits but real world is unnoticeable.
  10. Apr 19, 2024 at 11:30 AM
    azTony
    Tony
    Sun Lakes, AZ
    All I can say is I had an appointment with a contractor across town and I was running behind a little. I jumped in the truck at 23 degrees turned the key and took off. I had nothing out of the ordinary. It was in the back of my mind so I was listening and watching the gauges. No issue
  11. Apr 19, 2024 at 11:37 AM
    mass-hole
    mass-hole New Member
    This. The half a nanosecond the air spends is passing through the TB won’t affect the temperature in a meaningful way.
    May guess is this has more to do with the operation of the TB than actually heating the intake air.
    Also, at lower loads where your engine is operating in vacuum, I think there could be a benefit to warmer intake air from an mpg and power standpoint. And when you are at WOT the velocity and air mass through the TB is so high that there is little heat transfer.
  12. Apr 19, 2024 at 12:19 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Eibach pro 2.0s, toytec progressive mini AAL, ARE CX cap, Airlift bags, Harrop Supercharger, 650cc injectors, 77.5mm pulley, TRD Dual exhaust, J&L catchcan, Powertrax LSD, RRW RR7-H, 305/70r17 Toyo AT3s
    I figured this mod would be dumb and not have any effect for the reasons mentioned above, but I did it and actually have some basic data from before and after to say it does in fact lower IATs a measurable amount (8-12 degrees). My Harrop blower has an IAT sensor located post TB, SC rotors, and SC intercooler right before the air goes into the intake valves. See this post for my findings. I monitor IATs vs ambient pretty regularly as I drive. I was shocked to find it made any difference let alone that much of a difference.
    https://www.tundras.com/threads/general-supercharger-thread.85513/page-289#post-3209054
  13. Apr 19, 2024 at 12:24 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I suppose I'll knock this out this weekend on my 2uz 4runner and the Tundra...free awesome is the way to go!
    FrenchToasty and Silver17 like this.
  14. Apr 19, 2024 at 12:32 PM
    TacomaTRD4x402
    Southern California
    Thank you @Silver17
    Silver17[QUOTED] likes this.
  15. Apr 19, 2024 at 4:52 PM
    ZPhilip
    Philip
    West Chester, PA
    What size is the coupler to join the hoses?
  16. Apr 19, 2024 at 5:44 PM
    Silver17
    Eastern PA
    I used a 5/16 barbed coupling I believe.
  17. Apr 19, 2024 at 5:52 PM
    ZPhilip
    Philip
    West Chester, PA
    Thanks!
    Mdl likes this.
  18. Apr 19, 2024 at 5:56 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.2 SC pulley, ASP crank overdrive pulley, DD Full 3inch dual exhaust, Airbox mod, 4.5 intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, DIY Traction Bars, Tuning by snivspeedshop.com
    I just joined the 2. Survived the mild winter without it.
    Wynnded, Silver17, ZPhilip and 3 others like this.
  19. Apr 20, 2024 at 6:41 AM
    TacomaTRD4x402
    Southern California
    If I wanna put a vacuum cap over those open tubes on the TB, would a 5/8 cap fit?
  20. Apr 20, 2024 at 3:43 PM
    HulkSmurf14
    2014 Tundra Limited
    5/8" is too big...get 1/4" or 5/16" if avaliable...
    I just did this to both my 4runner and tundra today...SO much easier on the tundra with a SC as the TB is upside down!
    Mdl and Silver17 like this.
  21. Apr 20, 2024 at 3:53 PM
    Silver17
    Eastern PA
    Yes 5/16 caps are what I used.
    Mdl and HulkSmurf14 like this.
  22. Apr 20, 2024 at 4:30 PM
    TacomaTRD4x402
    Southern California
    Perfect, thanks guys. I was able to find a pack at O'Reilly that has an assortment of sizes.
    HulkSmurf14 likes this.
  23. Apr 22, 2024 at 5:11 AM
    ZPhilip
    Philip
    West Chester, PA
    Bypassed mine this weekend. Looking forward to lower IAT!
  24. Apr 22, 2024 at 5:26 AM
    TacomaTRD4x402
    Southern California
    Did mine yesterday, super easy mod :thumbsup:
    snivilous and HulkSmurf14 like this.
  25. May 2, 2024 at 5:10 PM
    scottgri
    scottgri New Member
    2019 tundra limited offroad
    None
    What all does this mod do. I just bought a 2019 tundra and I am trying to find out all the little tricks to do to it
  26. May 2, 2024 at 5:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The throttle body has a section for hot coolant to pass by the bottom area of the blade. It prevents freezing. Bypassing, should, reduces intake air temperature.
    HulkSmurf14 and TacomaTRD4x402 like this.
  27. May 2, 2024 at 5:24 PM
    TacomaTRD4x402
    Southern California
    Congratulations on the new truck. :thumbsup:
    The coolant bypass mod redirects coolant so it bypasses your throttle body thus keeping your throttle body at a slightly cooler temperature which would allow for colder air intake. This is one of those mods that can be debatable whether it actually provides any gains at all. I did see a test though where temp checks were done before and after and showed that the temps were slightly lower after the mod. You'll likely see different opinions on here and on YT.
    It's not a good idea to do it if you live in a cold climate as the coolant flowing through the throttle body keeps your throttle body from freezing and becoming stuck. I live in Southern Cali where we never see snow so doing this mod wouldn't really negatively affect me.
    Edit: it's actually here where I saw the tests... See @Silver17 post #12 above where he actually runs the tests :bowdown:
    Saltyhero13 and HulkSmurf14 like this.
  28. May 2, 2024 at 6:00 PM
    HulkSmurf14
    2014 Tundra Limited
    It's only "bad" to do if you put the truck in extreme temperature deltas...like -30°F outside to 50°F garage heat and back into -30°F...that's when the higher temperature TB will benefit from not icing up the condensation as the TB heats up fast.
    TacomaTRD4x402 likes this.
