Desperate for airbags or something to eliminate rear sag
Discussion in '3rd Gen Tundras (2022+)' started by ToyotaTundraguy, Jun 15, 2022.
  1. Apr 14, 2024 at 8:13 AM
    #151
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    2022 Limited Crewmax L
    MBM - TRD Offroad
    The RAS could work well on 2021's and earlier but the Gen 3 coils are different.
    @Mattedfred made a great point to start with a WDH and then go from there, then try airbags if you still need some lift in the rear.
    You could add taller coils to the back too but that would affect the everyday use of the truck where as airbags could be deflated when not needed.
    Spartanfam, Polo08816 and Mattedfred like this.
  2. Apr 14, 2024 at 9:54 AM
    #152
    NatesNightMare
    NatesNightMare Is what it is
    Nate
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    I plan on flipping the trailer axles. It sits real low as it is. My drop hitch isnt adjustable
  3. Apr 14, 2024 at 9:55 AM
    #153
    NatesNightMare
    Nate
    Pinetop Az
    No scales around here
  4. Apr 14, 2024 at 10:24 AM
    #154
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    I think the "Spring Over" idea is cool if you plan on taking this overland but if it were me, I would get a lower drop shank for your hitch so the trailer can run level and then get the truck to sit as level as possible using a WDH.
    I had a spring over setup in my Samurai many years ago and while the added lift was great, it made the ride very squishy. The forces on the springs change and ended up with springs breaking.
    My trailer has a 3" lift where the steel blocks add the height but the suspension is a torsion system in the axle so no springs. The blocks go between the frame and the axle mount. I also have a 6" drop shank with positions every inch which makes for easy adjustments.
    Keep us posted on your progress!
  5. Apr 14, 2024 at 10:33 AM
    #155
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It is interesting how much higher they make trailers now. I remember my parents trailer in 97 and the 2020 i have now needs more steps to enter than the old one
    NatesNightMare likes this.
  6. Apr 14, 2024 at 10:41 AM
    #156
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    I see some trailers out there that sit nice and high.
    My 2019 Airstream was soo low that we would drag the rear frame coming out of the driveway. I added the 3" lift so I could get it parked and not tear off the plumbing that is hanging very low!
    I added larger tires last year and raised it up another ~1". I went with 10 ply Falkens (trailer is a single axle so not too much sheer forces on these tires).
    I was worried about it becoming too tippy and sloppy in the wind but the lift hasn't made a difference at all.
    We just have to bring a portable step to fill the gap to the main step.
  7. Apr 14, 2024 at 3:13 PM
    #157
    NatesNightMare
    Nate
    Pinetop Az
    Flipping the axles on the trailer wont use blocks. It just flips so the leaf springs will be on top and still sit on the flat perch thats already there. We camp out in the off road mountains so flipping will def be a + also bringing it up to match truck. Im pretty sure ill pick up a wdh also. Theres one near me for cheap
    Lifer likes this.
  8. Apr 14, 2024 at 3:14 PM
    #158
    NatesNightMare
    Nate
    Pinetop Az
    Yeah flipping axles have been done since I was a kid also. My dad has done it a few times just to match the height of the truck and those were 5th wheels
    PBNB[QUOTED] likes this.
  9. Apr 16, 2024 at 6:59 PM
    #159
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    I was worried about towing our camper with a 3rd Gen Tundra, so test drove the camper with my friend’s Tundra first. It towed just as level as my F150, but with seemingly less effort. I towed my camper ~2500 miles this past month with my new Tundra thru the Appalachians to SC. No issues… Level too.
    (The parking lot had a crown to it so it looks a bit goofy.)
    I’m surmising folks are not setting WD up correctly.
  10. Apr 16, 2024 at 7:30 PM
    #160
    Breathing Borla
    Just wondering, but for you guys that knew you’d be towing etc, why didn’t you get the Toyota oem air bag system ?
  11. Apr 16, 2024 at 7:44 PM
    #161
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    We didn’t have the choice when we got ours. Very limited choice back when we got ours. And not a choice to add anything to the trim. We would have had to take a plat or higher to get air bags and but they weren’t coming up.
  12. Apr 16, 2024 at 8:04 PM
    #162
    Breathing Borla
    I thought you could get the oem system down to a sr5, no?
  13. Apr 16, 2024 at 8:43 PM
    #163
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    We don’t get the configuration options that you get down there.
    Wish we did!
    Cpl_Punishment likes this.
  14. Apr 17, 2024 at 5:46 AM
    #164
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Yes you can but actually finding one equipped like that was like me trying to find a DC 2wd longbed. Dam unicorns...
  15. Apr 17, 2024 at 5:54 AM
    #165
    Breathing Borla
    Bummer , it’s a great system
  16. Apr 17, 2024 at 7:55 AM
    #166
    Jckdanls07
    Jckdanls07 We May Not Know Them All, BUT, We Owe Them All !!
    Keith
    2015 White Tundra SR5
    That's exactly the truck I want... I would take air bags off my truck now and put them on that one...
  17. Apr 17, 2024 at 8:10 AM
    #167
    Spartanfam
    West Michigan
    I thought about it, but after calling BlueOx ta ask about setting up WD with air bags, they said that airbags reduce the amount of stress on the WD and thus reduce the effectiveness of the sway control. It makes sense to me so after towing with my friend’s truck (w/o air bags) I was sold. I did, however, specifically look for the TRD Off-road pkg because it has dual rate coil springs and monotube shocks…. Again, exactly as my friend’s truck had.
  18. Apr 17, 2024 at 9:02 AM
    #168
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Continuously adjusting airbags does present an issue with the wdh, as you dial it in the truck will keep adjusting the psi so it will probably take a lot longer
  19. Apr 17, 2024 at 9:45 AM
    #169
    j-utah
    j-utah Look Bodhi, people are dead, the ride is over.
    Utah
    Fort Collins, CO
    2024 Tundra SR5 (Bodhi)
    Dice valve stem caps (black)
    Here's an example working on right now getting this hooked up and adjusted for the first time. First trip leaving tomorrow, flat trip we are going east. I have a Sherline scale but have not weighed it recently, should be at 900 lbs with the propane. Will put it on the scale and add water. Was going to stay stock as much as possible, but going west I see a trans cooler in the future (sigh).
    CaptRussia253 and Cpl_Punishment like this.
  20. Apr 17, 2024 at 11:55 AM
    #170
    brtnstrns
    brtnstrns New Member
    2024 Tundra Platinum HV; 2022 Polestar 2
    Sort of regret not getting it since it'd probably be perfect for our little 20 foot Escape, but even looking at inventory now, it seems impossible to find a Platinum with AVS available anywhere nearby anyway.
  21. Apr 17, 2024 at 12:09 PM
    #171
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    When it malfunctions, will the truck be squatted to the ground even if the truck is unloaded? It's happened to plenty of Ram/Jeep vehicles along with GM SUVs.
    I would only opt for an OEM airbag system if it supplements coil springs or leaf springs.
  22. Apr 17, 2024 at 12:20 PM
    #172
    AZxp
    AZxp New Member
    '23 SR5
    Bingo
  23. Apr 17, 2024 at 1:02 PM
    #173
    Breathing Borla
    this isn't ram jeep or GM though, Toyota (Aisin) has used this for a long time, its proven, but to each their own. It works awesome for me so far, but respect the opposing viewpoint.
  24. Apr 17, 2024 at 1:28 PM
    #174
    Polo08816
    2014 BMW 335i
    I agree that Toyota will probably execute it better than most, but I believe the airbag-only design has it's inherent weaknesses over a longer time period. It's only a matter of time before those problems show up.
    I also think that well matched/tuned leaf spring/coil spring setups can function pretty well and should not be unbearably harsh either.
  25. Apr 17, 2024 at 1:55 PM
    #175
    j-utah
    Utah
    Fort Collins, CO
    I think the chances are really low (no pun intended). Everything is hooked up with the factory bags in the level/ neutral position, and the self leveling turned off. Once that’s all done, and the truck is turned on, the compressor turns on and re-levels the truck. If there was a failure (electronic control or air compressor), the bags still have air and the sag before leveling is minimal. If the bags pop or leak, that seems really unlikely, but it could happen.
    Breathing Borla likes this.
  26. Apr 17, 2024 at 3:29 PM
    #176
    j-utah
    Utah
    Fort Collins, CO
    Edit: added a little bit of air from the neutral position, then hooked up the camper, then self leveling doesn’t have to work as hard when turned back on.
  27. Apr 17, 2024 at 7:59 PM
    #177
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    So I had a look at Toyota.ca to see if things have changed since we got ours.
    To get the Advanced package with air levelling. We wound need to pick at least a Platinum Hybrid.
    So or us Canucks, we would be limited to 3 trims, Platinum, 1794 and Capstone all of which are hybrids.
  28. Apr 18, 2024 at 7:38 AM
    #178
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    The AVS replaces the coil springs rather than supplementing them?
  29. Apr 18, 2024 at 7:43 AM
    #179
    Polo08816
    2014 BMW 335i
    So my understanding is that Adaptive Variable Suspension and Load Leveling Rear Height Control Air Suspension are two different things, but they are often packaged together.
    I believe the Load Leveling Rear Height Control Air Suspension are, essentially, air bags that replace the coil springs.
    The only system I'm familiar with where OEM air bags supplement coil springs/leaf springs for the rear axle are on the Ram 3500. But I think this option reduces the number of leafs in the leaf pack compared to the standard feature (no air suspension).
    If the air suspension failed in the 3500, you could un-hitch your trailer and drive un-loaded. If your air suspension failed in a system which replaces the coil springs/leaf springs with an airbag, you run the risk of the vehicle being squatted to the ground and, perhaps, undrivable.
  30. Apr 18, 2024 at 8:09 AM
    #180
    Breathing Borla
    yes load leveling and AVS are not the same and not always together, in the lower trims they are never together.
    they only way you would have an issue is if an air bag popped, but you can also have a coil or leaf break, same thing.
    the auto level air system is great and I recommend it to anyone who hauls or tows often.
